Results 1 to 5 of 5
  1. #1
    Default "i have a 200 Johnson. When we
    "i have a 200 Johnson. When we get over 4,000 rpms a steady beep a light comes on. But we have a low oil light and temp light so its neither one of these problems. does anyone have any suggestions?"
  2. #2
    Join Date
    Mar 2004
    Location
    Posts
    385
    Default Could be a fuel delivery probl
    Could be a fuel delivery problem. Ck you lines and filters for stopage or leaks.
  3. #3
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    14,309
    Default "In agreement with Willard'
    "In agreement with Willard's reply and adding to it.....
    (Fuel Anti Siphon Valve)
    (J. Reeves)
    Many of the later OMC V/6 engines incorporate a fuel restriction warning via a vaccum device attached to the powerhead. If the engine overheats, or if you have a fuel restriction, the warning is the same.... a steady constant beep.
    NOTE... Only the V/6 & V/8 engines have the above "Fuel Restriction Warning". The warning horn will not sound on the other models.
    The fact that a engine is not overheating, but the warning horn sounds off with a constant steady beep, and that the rpms drop drastically would indicate that the engine is starving for fuel due to a fuel restriction. Check the built in fuel tank where the rubber fuel line attaches to the tank fitting. That fitting is in all probability a "Anti Siphon" valve which is notorious for sticking in a semi closed position. It will be aluminum, about 2" long, and the insides of it will consist of a spring, a ball, and a ball seat. If this valve exists, remove it, knock out those inner components which will convert it to a straight through fitting, then re-install it. Hopefully that cures the problem.
    The above procedure will cure a restriction problem with the anti siphon valve as stated. BUT, it may also allow fuel to drain backwards to the fuel tank when the engine is not running (siphoning backwards) due to the fact that the carburetors/fuel pump etc are higher than the fuel tank. This condition is not an absolute as the valves in the fuel primer bulb usually prevent this backwards siphoning problem. However.... if this does take place, the cure would be to install a new anti siphon valve."
    We occasionally have questions. If you fail to answer, it may affect ours.
  4. #4
    Join Date
    Dec 2005
    Location
    Port Charlotte, Florida, USA
    Posts
    108
    Default Joe I just read your posting o
    Joe I just read your posting on valve in tank I have a 1996 V4 90hp still having trble with the check engine light staying on and horn sounding for about a minute or so when running at all speeds I have put new water pump and new thermostats in engine runs great no decrease in rpms just that stupid light staying on do you think it could be that tank valve???
  5. #5
    FRED FITCH IV's Avatar
    FRED FITCH IV Guest
    Default "QUESTION FOR JOE REEVES ABOUT
    "QUESTION FOR JOE REEVES ABOUT THIS CHECK ENGINE LIGHT I HAVE BEEN WORKING ON A 2000 175HP JOHNSON DOING THE SAME THING CHECK ENGINE LIGHT A SLIGHT HIGH SPEED SPUDDER NO FUEL TROUBLE (POSITIVE) MOTOR RUNS FINE AT ALL RPMS JUST DOES IT SOMETIMES MAY SHUT DOWN AND NOT RESTART FOR A WHILE, WE HAQVE CHANGED EVERYTHING EXECPT CHARGE COIL ANY IDEA???"
Similar Threads
  1. Check Engine Light 2002 Johnson 175
    By tfasano in forum Johnson Evinrude Outboard Archive
    Last Post: 06-19-2007, 08:35 AM
  2. 1999 johnson 150 oceanpro check engine light
    By 4tbb in forum Johnson Evinrude Outboard Archive
    Last Post: 05-26-2007, 07:13 AM
  3. Check engine light alarm 200 Ocean Pro
    By kmccarthy in forum Johnson Evinrude Outboard Archive
    Last Post: 07-31-2006, 09:32 PM
  4. 996 Johnson check engine light
    By whelaniii in forum Archive 2003-2009
    Last Post: 12-19-2005, 02:33 PM
  5. Check Engine buzzer and light 1999 90 hp Johnson
    By Bill Nickerson in forum Outboard motors archive 2000-2004
    Last Post: 10-17-2002, 07:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
