Results 1 to 2 of 2
  1. #1
    Jay Alexander's Avatar
    Jay Alexander Guest
    Default I have a mid 90's model 40
    I have a mid 90's model 40 HP Tohatsu outboard. I need to clean the carburetor because I let it sit up too long. I made the mistake of fiddleing with the adjustment without making note of where it started. Does anyone know the carburetor adjustment to start with?
  2. #2
    softballdad's Avatar
    softballdad Guest
    Default I'm in the same pontoon wi
    I'm in the same pontoon with you. M40D tohatsu 1993. Sat for 2 years. Drained gas and oil and put in fresh but can't get to run very well (if I put on about 1/4 choke can get about 4000 Rpm. 2500 Rpm without choke. Neighbor says floats in carb probably gummed up but don't know how to fix it myself. Any ideas?
Similar Threads
  1. 83 dt40 carburetor adjustment
    By solarwolf in forum Suzuki Outboard Forum
    Last Post: 06-18-2009, 04:32 PM
  2. 1995 115 carburetor adjustment
    By pullendrag1 in forum Mercury Mariner Outboard Archive
    Last Post: 05-17-2009, 10:45 PM
  3. Carburetor linkage adjustment 98
    By srenity in forum Nissan Tohatsu Outboard Forum
    Last Post: 02-17-2009, 02:18 PM
  4. Carburetor Adjustment
    By aabond in forum Johnson Evinrude Outboard Archive
    Last Post: 10-06-2006, 06:08 PM
  5. Carburetor Adjustment
    By Joseph Czech in forum Outboard motors archive 2000-2004
    Last Post: 09-06-2002, 01:04 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
