Spun Prop Hub
rob
"Hi guys,
Had the boat out
"Hi guys,
Had the boat out at noticed that just after getting up to full throttle the engine rpms increased without any increased power from the prop. Is this likely a prop issue or lower unit issue?"
"Put a mark on the prop and al
"Put a mark on the prop and also on the hub.Run it and then remove and inspect the marks.If they have moved, get the prop repaired"
