Toe inout or none at all
C
clay lindsey
Guest
I have twin 1995 Evinrude 225
I have twin 1995 Evinrude 225 HP motors. One is counter rotating.Do they need to be toed in or out for proper tracking ?
"Clay,
On an outboard appli
"Clay,
On an outboard application the only purpose of tow in or out would be to keep any play in the tie bar from chattering. The offset adjustment will keep slight pressure on the steering linkage and keep it tight. I wouldn't go more than 1/2".
Good luck
Rick"
"Strongly recommend buying the
"Strongly recommend buying the factory manual. It tells you all the particulars about set-up, and toe in & out. The marina that set mine up didn't know what they were doing."
