"G'day Everyone,
I am hop
"G'day Everyone,
I am hopeing someone will be able to help me with a possable carby issue I am having.
I have recently purchased a 2002 bayliner 175 with a 3.0l 4cyl mercruiser engine, The boat had completly sunk in salt water and was not serviced after it was recovered, I removed the engine and rebuilt it. I also replaced all the wiring connectors, switches, and everything electrical that was damaged by salt water, I have replaced all bearings and seals in the sterndrive, I replaced the iginition coil, dizy pick up coil and module, I purchased a rebuilt carby from the USA that was meant to be a bolt-on replacement for my mercarb, It is called a rochester, I finaly got it all back together and running this weekend and all is good except the engine runs very very ritch and rough due to the ritchness, The grass at my girl friends place where I have had it running is sooty black ( she is not very happy with me)
and the area around the exaust on the hull has also turned sooty black, You can also smell the unburnt rich smell when its idleing and when u accelerate, The engine can sometimes be very hard to start when cold and I have to disconect the linkage from the throttle cable and hold it about half open to get it to start as it just coughs and splutters otherwise. I followed the timing procedure in the manual and the timing is spot on. I have emailed the person that I purchased the carby from and he advised he thinks my fuel pressure is to high, I checked the fuel pressure today and it was around 6 psi, he says it should be about 4-5psi, Mercury say it should be 5 1/4 to 6 1/4 so I don't believe this is the cause as I also ran the engine for about 30 seconds on the fuel in the bowl with the fuel pump disconected and it still ran very ritch, what I have also noticed is a very strong unburnt fuel smell from the breather hose coming from the top of the rocker cover. The choke operates as it should, There seems to only be a idle mixture screw on the bottom of the carby which makes no real difference to how it runs. how else would I adjust the mixture ?? would I have to replace the main jets with a smaller size ?? if so does anyone know if the Mercarb jets would be the same as a rochester? The carbs visualy look the same. what else should I look out for in the carb?? I have had very limited to do with carbs in the past, 99% of my mechanical experence is on injection. does anyone have any other suggestions to the rectify the richness ??
thanks Juz"
I am hop
"G'day Everyone,
thanks Juz"
