How are small Chrysler 4 HP engines cooled
roopzz
just wondered if someone could
just wondered if someone could tell me how the cooling system works in a 2 stroke outboard?
thanks
"In a water-cooled engine, coo
"In a water-cooled engine, cooling is provided by a (water pump).
In the lower unit there is an "impeller" either around the drive shaft or the prop shaft that forces water out of it's housing up a water tube to the water jacket and channels surrounding the cylinders.
The water exits down the exhaust housing, thus providing two addition functions after it has cooled the power head - it also cools the exhaust to some extent and acts as a muffler to keep some of the noise down...."
I have a 9.9 sea king and was
I have a 9.9 sea king and was wondering if the engine needs to be in gear in order for the impeller to circulate water?
"I believe some of the older C
"I believe some of the older Chrysler one-lungers had air-cooled cylinders. If so, the water pump only cools the exhaust leg, and the cylinder block will have fins on it and the flywheel will have fan fins."
