Lowerend replacment
wyattbear
79 seahorse 100hp v4 what lowe
79 seahorse 100hp v4 what lowerends will interchange with this powerhead. Also does the motor have to be running to change gears;.
"many lu will fit---unless u h
"many lu will fit---unless u have severe damage to the LU hsng,...it is usually best to repair/rebuild YOUR unit,..instead of taking a chance on another used one...the unit (gears,) need to be turning for the clutch dog to engage the gears right...either by turning the flywheel,spinning the prop shaft,or having eng running."
