blue_shark
"Hello all,
I just found th
"Hello all,
I just found this excellent forum.
I have a problem that some of you guys might be able to give me some advice on.
I have an Iveco 8361 SRM40 (400bhp @ 2400rpm) lately the engine(2000 hours now done) has developed a strange fault. If you drive the boat it is going like a clock right temp, exhaust is clean, starts and stops normally. But when you take the boat out of gear (or drop to almost idle speed in gear) after steaming, after about 30-40 seconds the exhaust begins to steam excessively. The steam possibly smells a little like engine coolant.
She loses some coolant from the header tank, she might take a litre or so after a days running. The expansion tank doesn't hold coolant I noticed this since I changed the water filter at about 1500hours (may be just a coincidence) the expansion tank is dry, if I fill it to the "min" mark it is empty again the following morning.(this was happening well before the steam issue).
The head gasket and turbo are both OK.
Any advice on where to start looking for this problem.
Any advise will be greatly appreciated!!
Jim"
I just found th
"Hello all,
Jim"
