"I want to replace all my oil
"I want to replace all my oil seals this year on my lower unit. I had no problem removing the gaskets and seals from the water pump side, but when it comes to the prop end I have a question. After removing the prop thrust hub I can see 1 of the 2 water seals on the prop shaft. my question is do I have to remove the whole bearing assembly to drive out the seals from the "front" side, or is there some type of puller that will wrok on these seals?"
