DT 55 Buzzer not sounding
andy_k
"Hi I recently purchased a DT
"Hi I recently purchased a DT 55 the buzzer was working but is now not I took it out and tested it and it works fine but not when connected to the remotes, has anyone got any ideas what the problem could be? cheers Andrew"
"thats the problem it doesn&#3
"thats the problem it doesn't come on with the key, it used to and also stayed on when the motor was started until water pressure was acheived."
"Hi thanks for helping, I do h
"Hi thanks for helping, I do have 12volt at the box as the hour meter still goes with the ignition on and the motor can still be started from the key? cheers Andrew"
"Hi I have isolated the proble
"Hi I have isolated the problem to the blue wire that comes from the CDI unit on the motor it appears to be an earth but no longer working.I have ordered a manuel to help , can I open the CDI up to continue tracing the fault?"
"Thanks so much for your help,
"Thanks so much for your help,the manuel should arrive tommorow , is the problem not serious?"
