timvanderveen
"My volvo 5.7L penta engine ha
"My volvo 5.7L penta engine has approximately 100 hours. The engine failed to start as we were launching, then would not turn over. The problem was intitially thought to be the starter motor, but later the dealer found water in the cylinders and described this as a hydrolock. The heads checked out OK. The only explanation I have been given is the engine ran backwards. It never started, but it did initially turn over on its own after the key was off.That happened right before it locked up. So far there are no defective parts, but the water sat in the engine for several days before the hydrolock was diagnosed. I would be most appreciative if someone could help explain. Thanks"
