" Hello all -
Last week I p
" Hello all -
Last week I picked up a 1984 Evinrude 4HP motor that had not been used in 5+ years.
After cleaning the fuel tank, fuel line, carb float bowl, replacing the plugs and replacing the lower unit gear oil the motor started on the second pull and runs smoothly.
My question is: There does not appear to be a "pee hole" on this motor - How can I tell if the water pump is working correctly? I pulled the lower unit and took a look at the water pump and it looks OK. However, I did not disassemble the pump to inspect it.
Thanks in advance. "
Last week I p
" Hello all -
