TAMD 41 OIL
haltoyone
I have twin TAMD 41 volvbos wh
I have twin TAMD 41 volvbos what is the recomended oil for the engines and transmissions
right now i am getting ready to use DELO 15/40
diesel oil
"oil is correct. Gear oil depe
"oil is correct. Gear oil depends on model of gear. Most Volvo gears from MS3B up took 80/90 GL5 lube.MS4/5 took synthetic 75/90 gear lube. Borg Warner,HS45 took ATF. HS1 gear took engine oil."
Thank you I have VOLVO HSIA wh
Thank you I have VOLVO HSIA which means that I
can use the same oil that I use in my engines
DELO 15/40
