C
chris whipple
Guest
"I rebuilt a 2bbl mercarb off
"I rebuilt a 2bbl mercarb off a 1987 seaswirl 4.3 sterndrive and since then it bogs and pops at wot. I can back off the throttle and run the lake all day.
I finally realized it is running rich. My lake altitudes are between 5600-7600 feet above sea level. I realized the jets are 165 which is sea level jets. When i replaced them with 155s now I get wot but it still bogs a little when I back off the throttle, Then comes to life when i back off a little more. RPMs went from 4650 to 4800 with that jet change. I have 150 jets on order.
My question is. Is it possible to lean out this carb other then replacing the jets?
Something I did when I rebuilt it changed it.
I set the float to specs. Is it possible the previous owner dropped the float level to lean out for high altitude?
It ran good before I rebuilt it.
I even went back and replaced all the original parts in the carb.
The only thing I can see that might be different is the float setting."
