"My 1974 M360 does not have an
"My 1974 M360 does not have any identification tags period. The engines are newly rebuilt prior to my possesion. I had to install the port engine. Ok question is: Book says when viewing prop from rear, engine rotataion is viewed as same. Then it says "for L10,L13,L15,L25,L30, and R19* firing order is 1-8-4-3-6-5-7-2"
*The exception for the design of Warner Reduction gear results in the prop shaft turning opposite direction of the engine. When I place the transmission in forward gear the shaft turns Counter Clockwise the engine turns Clockwise with starter enguaged. So is the above firing order correct?"
