"Lee:
You may have some cor
"Lee:
You may have some corroded connections on the ignition amplifier attached to the port side of the engine. Remove the + battery cable from the battery and starter and clean all 4 connections first. Next remove and clean the main engine ground from the battery; clean both ends of the cable and block area. Then remove the ground on the amplifier and clean it. Do the same on the coil, both connectors. Inspect the amplifier quick connects and clean as needed. If it does not improve, Perform the test below. I would buy a new coil before I spend $450 on an amplifier unless the amp. fails the tests.
Tests for Thunderbolt Ignition:
W/ignition key on AND BILGE WELL VENTILATED OF GAS FUMES!!!
#1 - Connect your voltmeter neg. lead to the engine ground and pos. lead to the white/red wire terminal at the dist. It should read 12 volts.
#2 - If 12 volts is present, remove the coil spark wire from the distributor and connect it to a spark gap tester to ground. Remove the white/green lead from the dist. terminal. Turn the ign. key to on and strike the white/green lead to ground. If there is spark, replace the ignition sensor in the dist.
#3 - If there is no spark, substitute a new coil and repeat test #2. Now if you get spark, install a new coil. NO SPARK, replace ign. amp.
#4 - In #2, if there is No voltage present, disconnect the white/red wire and check it again for 12 volts. If 12 volts is present, replace the ignition sensor inside the dist. cap. If no 12 volts present w/it disconnected--ignition amplifier is shot and must be replaced."
