Results 1 to 5 of 5
Thread: Carb problems
  1. #1
    Join Date
    Oct 2007
    Location
    Yuma, Colorado, USA
    Posts
    3
    Default "Know its plugged from bad fue
    "Know its plugged from bad fuel. how do you get itout of the engine, Sea King 15 VWB 52119B"
  2. #2
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,266
    Default "You take the carb off,+ s
    "You take the carb off,+ soak it in Carb Cleaner......"
  3. #3
    Join Date
    Oct 2007
    Location
    Yuma, Colorado, USA
    Posts
    3
    Default "Thank you, but this little do
    "Thank you, but this little dog has two parts that hold the carb from coming out. There is the shift handle inside that dont give the space I need to get it off the two bolts, just wondering if there is another way, thanks again, John"
  4. #4
    Join Date
    Dec 2006
    Location
    Posts
    5,266
    Default "Although I don't know you
    "Although I don't know your motor,......
    For what it's worth,......
    After Mechanicing on about everything that moves, for the last 40 years,....
    I've found that you Usually have to remove a Whole Bunch of stuff that's in your way,....
    Before you can actually work on the part you Want to work on......."
  5. #5
    Join Date
    Oct 2007
    Location
    Yuma, Colorado, USA
    Posts
    3
    Default "Thank you for your kindness,
    "Thank you for your kindness, I did what you suggested, and got the little guy out, and was lucky enough to find a marine outfit to send me a kit, thank you again, John"
Similar Threads
  1. carb problems
    By jcardenas53ymail.com in forum Johnson Evinrude Outboard Forum
    Last Post: 07-21-2010, 09:39 PM
  2. carb problems
    By Michael Bowles in forum Johnson Evinrude Outboard Forum
    Last Post: 05-17-2010, 09:25 PM
  3. Carb problems still
    By captal in forum Crusader Marine Archive
    Last Post: 01-05-2009, 11:26 PM
  4. Help with carb problems
    By barnfinder75 in forum Mercury Mariner Outboard Archive
    Last Post: 06-25-2008, 10:21 AM
  5. 318 carb problems HELP
    By andrewmaeyaert in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 04-21-2008, 01:32 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
