Results 1 to 4 of 4
  1. #1
    Join Date
    Oct 2007
    Location
    Victoria, British Columbia, Canada
    Posts
    3
    Default "I bought a 2000 8 hp extra lo
    "I bought a 2000 8 hp extra long shaft outboard a year ago for trolling and auxiliary on my 28'displacement craft. It worked wonderfully this season, a great relacement for the Seagull.
    When I brought it home for maintenance recently I discovered considerable salt deposits on the cylinder heard, around the spark plug bosses and ridges. Where would it come from? Could it be a pin hole leak in the head gasket that allows salt water to ooze out and evaporate. It is stored horizontally on the swim grid when not in use. The cowl seems to fit well and tight. The deposits were only on the cylinder head surface into which the spark plugs screw."
  2. #2
    Join Date
    May 2007
    Posts
    9,267
    Default "Grant, sounds like your think
    "Grant, sounds like your thinking along the right line. Could be a bad head gasket allowing a little bit of water into the cylinders.
    Gaskets are cheap, and not difficult to change. Probably worth doing - even just to rule it out as the issue..."
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
  3. #3
    Join Date
    Oct 2007
    Location
    Posts
    3
    Default "I have discovered the source
    "I have discovered the source of the leak. there is a small chip out the edge of the plastic thermostat cover. So all I need do is get new thermostat cover. Something else about this engine, I drained and replaced the bottom end gear lube, the old stuff was very dark, almost black - any thoughts on that"
  4. #4
    Join Date
    May 2006
    Location
    pensacola, fl., u.s.a.
    Posts
    1,366
    Default just old. change it every year
    just old. change it every year.
Similar Threads
  1. Tamd41 p with salt water in head
    By neilrob in forum Volvo Penta Diesel
    Last Post: 02-25-2011, 07:08 PM
  2. Older 2-strokes, cylinder head "salt weep"
    By HalfScoop in forum Yamaha Outboard Forum
    Last Post: 02-05-2011, 06:11 PM
  3. changing thermostats and salt deposits?
    By urbanrenewal in forum Honda Outboard Forum
    Last Post: 12-11-2010, 04:19 PM
  4. Torque on Johnson 6hp cylinder head bolts
    By Nickoloas Kosmenko in forum Johnson Evinrude Outboard Archive
    Last Post: 10-25-2006, 06:22 PM
  5. Repairing salt damage at head amp cylinder
    By steve b. in forum Archive 2003-2009
    Last Post: 09-06-2003, 09:04 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
