I am installing an electronic
I am installing an electronic ignition on my 3.0 and someone told me to do the following because this is what they had to do to get it to work. Can anyone verify this. They took out the old components and installed the electronic ignition parts. Next they located TDC and set the engine to zero. Then they rotated the distributor until the pickup on the electronic ignition was at the number one plug location with respect to the wire in the cap. After that they started the engine and set the timing. I think I have this about right. Is this the correct procedure?
