Chrysler 318 no spark
M
michael curley
Guest
"I attempted to clean out one
"I attempted to clean out one of the exhaust manifolds by shooting a hose through one end of the manifold with the drain plugs out. I got a lot of rust and crud out, but now I can't
get the engine to run. Replaced starter, battery, solenoid, plugs.
Doesn't turn over strong and won't ignite starter fluid. Any help is appreciated."
"Pull the plugs and pump the w
"Pull the plugs and pump the water out by turning it over. Never, ever do that! You pumped water into every exhaust port on tat side.
Jeff"
