Can you replace a alpha 1 w a Alpha Gen 2 Drive
mikem40
Wiil a alpha 1 gen 2 bolt righ
Wiil a alpha 1 gen 2 bolt right up to a where a alpha 1 was?
I need to replace the drive because the bearing is shot in the upper
TIA
"try sterndrive engineering fo
"try sterndrive engineering for a cost effective replacement. www.sterndrive.cc
I've used them and have put hundreds of miles on their drives. They passed my skeptical diligence. A good replacement provided you aren't melting them with high HP."
"the reason for it mike is the
"the reason for it mike is the gimble housings are different, the sterndrive is a good replacement."
