"This may be a seperate issue
"This may be a seperate issue with oil in bilge.
If it is a hull leak, I say what leaks in will leak out. Filler up with water (on the trailer), same amount you found on the river, maybe more, short of soaking the starter motor, and stand back and see where it leaks out. If nothing comes out, you may have a leak in the sea water hose or (bite my tongue) a leak in the block/engine or some of the coolant hoses.
However, if motor runs ok, cracked block in water jacket is not that bad of thing. More on that later, depends on what you report.
Once, when fish'n on the Columbia R. I woke up to see my shoe float by at eye level. It was a leak in the head (toilet)."
