Results 1 to 9 of 9
  1. #1
    knucklehead's Avatar
    knucklehead Guest
    Default "Anybody have an approximate f
    "Anybody have an approximate fuel consumption for a 32' Regal w/two 7.4 liter beasts in say gallons per hour at cruise (approx 28knot, so I'm told)"
  2. #2
    Join Date
    May 2007
    Location
    Inverary, Ontario, Canada - The Great White North Eh!
    Posts
    9,127
    Default "I have test numbers for both
    "I have test numbers for both the 5.7's and newer 8.1's - I can post both here - yours should fall somewhere in between - the bottom line is though, it's going to suck alot of gas [img][/img]
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
  3. #3
    Join Date
    Sep 2007
    Location
    USA
    Posts
    208
    Default you can probably add 5 to 7 ga
    you can probably add 5 to 7 gal per hour at 3500rpm to that as the GL's are carbed and these examples are injected.
  4. #4
    Join Date
    May 2007
    Location
    Posts
    9,127
    Default "Brett, you are absolutely rig
    "Brett, you are absolutely right. I half realized that when I posted the charts, but figured "hey, if you can afford to spend 60-70 bucks an hour in gas at cruise speed, what's another 20 bucks".
    I'll stick to my "little" outboards, clocked about 200 hours this summer and didn't quite burn 50 gals of gas [img][/img]"
    Graham
  5. #5
    Join Date
    Sep 2007
    Location
    USA
    Posts
    208
    Default "lol, i cant complain, have a
    "lol, i cant complain, have a 5.0gi on a 24ft cutty, fuel is not "that" bad, although 200 hrs and 50 gal, thats not bad either"
  6. #6
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,549
    Default Yoh! Note that the larger eng
    Yoh! Note that the larger engines (properly propped) in the same boat get better gas milage! Seen that pattern all the time.
    Jeff
  7. #7
    Join Date
    May 2007
    Location
    Posts
    9,127
    Default "Jeff, yes, and makes perfect
    "Jeff, yes, and makes perfect sense, unless you go totally overboard with engine size, a larger motor (or twin set-up) isn't going to work near as hard as the smallest one you can get away with (which usually has a rediculously pitched prop on it, because "this guy" at the marina said a 23 pitch would work and you would get more speed)
    The better torque band alone in the bigger motor is going to allow the boat to get moving without the engine "breaking a sweat" and drinking lots of gas to do it [img][/img]
    But I guess it's all relative, 2 x 7.3L motors are what, a combined 900 or so cubic inches - that's alot of vaporized gas to fill those cylinders in anyones book - a whole lot more than the 16 cu in of my 15 horse, but of course I also run a 4 cu in, 2 cylinder 2.5 horse, to save gas when running slow [img][/img]"
    Graham
  8. #8
    knucklehead Guest
    Default "Thank you all, I was looking
    "Thank you all, I was looking to buy this type boat however the owner couldn't give me any details of the boat, being very evasive to any questions asked. This is a great service you all provide. Thanks"
  9. #9
    Join Date
    Sep 2007
    Location
    USA
    Posts
    208
    Default "Knuckle, that is a big stopsi
    "Knuckle, that is a big stopsign on buying a boat, anytime someone wont be up front about a toy, there is usually a problem with that toy. good luck on finding your next purchess"
Similar Threads
  1. 1985 Siverton wTwin 260 V6 Crusaders
    By bobovic04 in forum Crusader Marine Engine Forum
    Last Post: 12-14-2009, 10:30 AM
  2. New boater wTwin 318bs after warmup engine runs hot
    By frogwelder in forum Miscellaneous marine engine topics
    Last Post: 09-06-2009, 04:53 PM
  3. b72 Seabird V28 Sport Fisherman wtwin LM318 inboards
    By dirty_bird in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 08-15-2008, 12:31 PM
  4. Wiring diagram for CC Amerosport 333 flybridge wtwin 454
    By cruisers00 in forum Chris Craft Engine Forum
    Last Post: 06-21-2007, 07:08 AM
  5. Regal 402 WOT issue
    By Jim Roark in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 03-06-2006, 06:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
