Results 1 to 4 of 4
  1. #1
    Join Date
    Sep 2007
    Location
    woodland, ca, usa
    Posts
    1
    Default I recently purchased a 1987 se
    I recently purchased a 1987 seaswirl with a omc cobra sterndrive (4.3 engine). The boat takes on quite a bit of water. I tilted the boat up in front and filled the area under the engine with water to try and find the leak. It leaks out a pretty good stream between the bottom of the stern drive mount and the boats transom. IT runs down the transom. I doesnt seem to be coming from the boots. It hard to tell exaxctly where it is coming from but I assume it is between the stern drive mount and the transom. I assume there is a gasket of some kind betwen the mount and transom. How hard it it to remove the transom mount. Do I have to remove the engine?
  2. #2
    Join Date
    Apr 2006
    Location
    , Langkawi, Malaysia
    Posts
    5,750
    Default "Drive off, engine out is the
    "Drive off, engine out is the only way to go.
    I would eithr suspect a rotten transom or that the plate between the two lower studs was not installed at factory, only washer and nuts."
  3. #3
    Join Date
    Aug 2007
    Location
    England
    Posts
    65
    Default "Hi Morten, Further to your re
    "Hi Morten, Further to your reply above, what is that plate on the bottom 2 studs actually for? I noticed it on my boat but couldnt really see what it did!!"
  4. #4
    Join Date
    Apr 2006
    Location
    Posts
    5,750
    Default I have noticed on a few occais
    I have noticed on a few occaisions that when that plate have been missing the washers have cut through the glass-fiber and the torque pressure have been lost. That far down on the transom close to the bottom it is not allways 'straight' and as the transom gets 'watery' it gets soft. The plate protects the transom and spreads out the load on a bigger surface than the washers.
Similar Threads
  1. Outer transom plate leak
    By mashed_finger in forum OMC Sterndrive and Inboard Forum
    Last Post: 08-22-2010, 02:18 AM
  2. Transom Seal Leak Causes
    By cdi5344 in forum Volvo Penta Gas Archive
    Last Post: 10-23-2007, 06:16 PM
  3. 43 sx transom water leak
    By miket in forum Volvo Penta Gas Archive
    Last Post: 08-13-2007, 09:30 PM
  4. 1989 SEA RAY 250 DANCER TRANSOM LEAK
    By lawrence1106 in forum Mercruiser Sterndrive Archive
    Last Post: 07-22-2007, 09:34 PM
  5. Transom Leak
    By Merle Southern in forum Archive 2003-2009
    Last Post: 07-15-2003, 01:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
