"Hello, just completed rebuild
"Hello, just completed rebuilding a 1992 Tiller DT30C N-model Ser # 231945.
Replaced condensor charging coil, 1 piston, all piston rings and 2 bearings of crankshaft and oil drive.
Engine runs fine and steady at idle speed, now.
Once throttle is opened up more ( approx 1500 RPM )engine will stall. If throttle is advanced very quick,engine will accelerate to high/full speed ( approx 4000-5500 RPM range ). If throttle is reduced fast, engine remains running at idle speed and minimum throttle set.
Cleaned all carburators ( also High speed nozzle and Pilot jet )prior and changed diaphragm fuel pump.
Appreciate any input to my problem
Regards NUMA1"
Regards NUMA1"
