Prop size
marshall
"I have a 19' Bayliner wit
"I have a 19' Bayliner with an AQ 125/270. The prop on it now is off some other drive;15-3/4 x 17 with a center exhaust. At 4500 rpm I'm only running about 28mph. What is the original prop?
Thanks,
Marshall"
"That's not a bad speed bu
"That's not a bad speed but it's not the right prop for the V/P drive. Someone has rehubed it to fit the V/P shaft. Your boat should have a 14" diameter prop on it, you'll have to play with the pitch. I'm guessing 17"."
"I have the exact same boat, m
"I have the exact same boat, my prop is a 14x19 and she will max out at 4900 rpm at 35 mph with 4 adaults in the boat. Let me know if you can find any way to get 40 out of her."
Thanks Jordan!
You might have
Thanks Jordan!
You might have to throw a couple of the adults overboard. ha ha ;) 35 is a lot better than 25. It's usually just me and one other.
Thanks Guys!!!!
Who has the b
Thanks Guys!!!!
Who has the best price? I live in coastal Georgia. I'd prefer a stainless prop because of the salt but since I don't keep the boat in the water I can use an aluminum one.
Marshall
