skip_evans
"Hey everyone,
The boat h
"Hey everyone,
The boat has a 1980 5.7l mercruiser with an alpha 1.
I replaced the bellows, shift cable, gimbal bearing, and serviced the drive.
The boat ran great on the muffs for 15 minutes, and shifted fine.
I took it to the river. It ran great for 30 minutes. It was then hard to start once I turned it off for a short period of time.
I headed back in. It cut out. Once it started I couldn't get it to go in to gear. If, I throttled up, smoke would pour out. The smoke had a rubber smell.
It would only stay running for a short period of time The engine never overheated.
I took the shift cable off of the engine once the boat was on the trailer. I tested it by hand. The drive functioned fine. The engine was not running.
I'm thinking that the coupler went bad. I just don't understand why the engine would not run properly at the same time.
I realize that it would have overheated without the drive turning. I understand that the coupling possibly just went up because of age.
I just don't understand why the engine won't run. It wouldn't be under any strain. It would just overheat without the impeller in the drive cooling it. I feel that I'm missing something.
Actually, I'm probably missing everything. I'm fairly new at this.
Any ideas or suggestions would be greatly appreciated.
Thanks, Skip"
The boat h
"Hey everyone,
Thanks, Skip"
