Chris Craft 350Q
R
Robert Anderson
Guest
Does any one know if a CC 350
Does any one know if a CC 350q engine can be installed in a CC Catalina 251???
How many bolts must be loosen
How many bolts must be loosend in order to tighten the fan belt on on a 454 crusader engine.
Belt goes from flywheel to alternator only.
Is their a diag. of the bolt location. Engines are mounted in a 3100 Tiara.
Thanks for your help.
"climb inside the engine compa
"climb inside the engine compartment and look at the front of the engine it's pretty obvious ,normally there is two bolts."
