B
BrianP
Guest
" OK here's the deal. I ha
" OK here's the deal. I have 90lb compression in all 4 cylinders. I have spark through the spark plugs. While idleing I pull the plug wires 1 at a time, when I pull each of the wires (one at a time) each top one will almost kill the motor, the bottom 2 make no change like they're not firing but are wet with fuel. I can pull the plug and hold to a ground crank the motor and the plugs are sparking good (they're new). It will turn about 5000rpm on the lake but won't hardly idle because it seems to only be running on 2 cylinders. Any ideas??
Thanx in advance
Brian "
Thanx in advance
Brian "
