M
mark klaben
Guest
Purchased a new omc trim send
Purchased a new omc trim sender. It appears that I have to remove the outdrive to feed the wire through the upper portion of the outdrive into the engine compartment. There is a grommet were the wire goes into the engine compartment through the outdrive. Does any one have a suggestion as to how to feed the wire through without taking the outdrive off. Unfortunatly with the sender there is no installation instuctions. As well the chilton book dosent go into how to change this. Looking for any suggestions.
mark
mark
