D
denrbub
Guest
I have a 75hp 3 cylinder Mari
I have a 75hp 3 cylinder Mariner outboard oil injected. I have a intermittent beeping sound with the key in the run position and when running. The oil reservoir is full and i replaced the low oil sensor. I have disconnected the the low oil sensor at this point. What type of alarm would i get if the oil pump is not working? Would i get a engine overheat alarm if running without oil?
