NEED HELP W MOTOR
jim
" I HAVE A 4 CYLINDER VOLVO EN
" I HAVE A 4 CYLINDER VOLVO ENGINE, I NEED TO KNOW IF I CAN USE MY OLD OUTDRIVE W/A BIGGER ENGINE? "
" Drive can be used, but gear
" Drive can be used, but gear ratio will more than likly need to be changed so boat can plane and run at proper RPM "
" DOCKTOR O.B.I.O. I'VE LO
" DOCKTOR O.B.I.O. I'VE LOOKED ON THE NET AND CHECKED EVERY CLASSIFIED AND TRADER, I'M LOOKING FOR A CHEAP V-6 OR MAYBE A WHOLE NEW SET-UP A LITTLE MORE POWERFUL. CAN YOU HELP OR GIVE ME A RESOURCE TO GO BY. THANKS JIM "
" Jim, One major considerati
" Jim, One major consideration for you, if you change manufacturers to a different replacement unit, (change to Mercruiser, OMC, Yamaha), you will also require a different shape hole in the transom of your boat to accept the new outdrive. As to where to look for such items, you are probably searching the best site on the internet, marineengine.com Have a great day. "
