MarineEngine.com - Your online store for all types of marine engines and boat parts.
Order by phone
(800) 209-9624
Monday - Friday
8:30 AM - 5:30 PM EST
Safe Online Orders
Comodo Enhanced Security
Special $9.95 Flat Rate Shipping
Boat Repair Forum Boat Repair Forum     Boat Video Gallery Video Gallery
Home | Contact | Shipping | Returns | Cart View your shopping cart.
Part Number Search
Shop by engine/drive part number.
Original & matching parts for sale.
Manuals & Accessories
Shop by description, item number
or manufacturer's model number.
Results 1 to 4 of 4
Thread: 140 evinrude
  1. #1
    gary armstrong's Avatar
    gary armstrong Guest
    Default just wondering about water pu
    just wondering about water pump does water come out of each thermosate equal pull one hose loose and and water run good pulled other hose and very little water came out can you explain the way the water goes in and out of the engine thanks gary
  2. #2
    Join Date
    Feb 2001
    Posts
    10,784
    Default "Gary.... The water enters the
    "Gary.... The water enters the powerhead first and circulates through the various water passages there. The water then exits from the cylinder heads at the lower water casting (where the hose attaches)... and at that point the water enters the thermostat (vernatherm) area. In that thermostat area, there are also water bypass valves which allow water to bypass the thermostats at a high rpm if needed. However, pertaining to the thermostats, when they open at approximately 143°/148°, the water continues on its way to an exit which are slots or holes just above the cavitation plate (the plate above the prop)and to the rear of it.
    Pertaining to the difference in water escaping from those lower castings in the heads when you remove the hoses... ignore that. That's due to the fact that the water entering the powerhead is simply closer to one head outlet than the other. When the engine is together as it should be, this water pressure equalizes. In short, what you're seeing is normal.
    Joe[img][/img]"
    Our questions require answers. If you refuse to answer our questions, how can we answer yours?
  3. #3
    Join Date
    Jun 2002
    Location
    Posts
    129
    Default thanks joe one more for you m
    thanks joe one more for you my water pressure guage does not work when i pull the hose loose i get no water so water does not enter the hose to the guage thanks gary
  4. #4
    Join Date
    Feb 2001
    Posts
    10,784
    Default "Gary.... As I mentioned, the
    "Gary.... As I mentioned, the water pressure goes to the powerhead first, and foremost it goes to the exhaust baffle manifold cooling area (the wide plate between the cyl heads) if it's a crossflow engine. The water telltale outlet hose (where the water pressure gauge should be spliced into) should be located at the lower starboard (right) corner of that plate..... if this is a crossflow type V/4 140. Refresh my memory as to what year this 140hp is.
    At any rate... if you have no water coming out that fitting where the water gauge is connected, and you're sure the water pump is okay, I would venture a guess that the connector at the block is clogged with salt, sand, something. Remove the hose and blow the fitting out with pressurized air.
    Joe[img][/img]"
Posting Permissions
  • You may not post replies
  • You may not edit your posts
