Results 1 to 3 of 3
Thread: Carb Tilt Plate
    Michael Stevens's Avatar
    Michael Stevens Guest
    Default I am repowering a 1968 Luhrs
    I am repowering a 1968 Luhrs with twin Crusader 270's but I am switching them from conventional to V-Drive. My problem is the carbs are tilted in the wrong direction. Does anyone know where I can find a Tilt/Shim plate opposite of the ones I have?
    I dont want to have a float problem later on.
    Thanks.
    Poopiepantz's Avatar
    Poopiepantz Guest
    Default "Interesting change. What is
    "Interesting change. What is stopping you from rotating the plate 180 degrees and rerouting the throttle cable mount connection? The exhaust manifolds ar being turned also. I'd contact http://ebasicpower.com/ if you don't get a better answer her and ask them."
    Jul 2002
    92
    Default Mike if using a v-drive the m
    Mike if using a v-drive the motor sits very close to level and will not need a wedge plate. I have a 1976 Luhrs set up this way and have had others in the past with same.
  1. 86 mercruiser transom plate to a 91 transom plate
    By lime4x4 in forum Mercruiser Sterndrive Forum
    Last Post: 12-20-2009, 08:27 AM
  2. 1990 115 Merc Carb amp Jack Plate Question
    By capsboy02 in forum Mercury Mariner Outboard Archive
    Last Post: 06-24-2009, 12:31 PM
  3. Damaged Johnson 99 Carb Throttle Plate Shaft Assembly
    By paxriver in forum Johnson Evinrude Outboard Archive
    Last Post: 11-20-2008, 02:51 PM
  4. What is this plate on the 30
    By sknight88 in forum Mercruiser Sterndrive Archive
    Last Post: 07-06-2008, 08:57 AM
  5. Replies: 1
    Last Post: 10-29-2006, 11:56 PM
