Results 1 to 3 of 3
  1. #1
    Default " Joe I read in one of your pr
    " Joe I read in one of your previous posts concerning an 85 hp evinrude that you changed the size of the slow speed idle jets to eliminate or at least help with an idle problem.
    I have a 78 model 85hp Javelin that has always had a stutter at idle as well even tho compression and plugs etc have always been monitered and serviced,would you recommend doing this to my engine as well?? do they run the same jets? "
  2. #2
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    14,272
    Default "If the carburetors are absolu
    "If the carburetors are absolutely clean and nothing else will straighten out the idle, that would be the route I'd take.
    However, before drilling out those jets, I'd check to see if the original jets can be purchased at whetever location you're at just in case.
    The jets in that engine should be OMC part number 323003 which have a inside diameter of .025. The number 25 would be marked on the jet itself.
    If your jets are indeed .025, I'd try enlarging them to .027, just a couple thousands.
    Joe[img][/img]"
    We occasionally have questions. If you fail to answer, it may affect ours.
  3. #3
    Default " Thanks Joe I do appreciate y
    " Thanks Joe I do appreciate your help, I'll do a little more exploring with the jets before i do anything, not that the stutter at idle really bothers me but being an automotive mechanic for 25 years , spe******ing in Auto transmissions, i would like to make it idle perfect, Regards Brian "
Similar Threads
  1. Golden Javelin 35 HP
    By srma63 in forum Johnson Evinrude Outboard Archive
    Last Post: 12-06-2009, 09:54 PM
  2. Help with 35 hp Johnson Golden Javelin
    By benny_and_the_jets in forum Johnson Evinrude Outboard Archive
    Last Post: 05-29-2008, 12:43 AM
  3. Sparky 78 model 85 hp Javelin
    By briansal1 in forum Archive 2003-2009
    Last Post: 09-27-2006, 11:56 PM
  4. Seahorse 85hp javelin
    By Baz in forum Johnson Evinrude Outboard Archive
    Last Post: 08-29-2006, 01:17 AM
  5. Joe or anyone Overheat in Javelin 1978 Help
    Last Post: 04-19-2004, 06:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
