MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 8 of 8
  1. #1
    Wayne LHerpiniere's Avatar
    Wayne LHerpiniere Guest
    Default " Joe, I am rebuilding my
    " Joe,
    I am rebuilding my 1981 V4 140 Evinrude and would like to replace all crankshaft bearings. My local shop has told me that Bombardiar only supply the upper crankhead bearing in an assembly (with housing). I am wondering why I cannot just replace the bearings and seals (and save about $300)? The only thing I can think of is perhaps there is an alignment issue hence the lack of bearing only option from Bombardier. Any advise would be appreciated.
    Thanks (again)
    Wayne "
  2. #2
    Default Those bearings are usually ok
    Those bearings are usually ok to re-use.Is the upper journal worn at all or is it within factory specification.There really is not much load on the upper bearing.
  3. #3
    Default " Sparky, The journal
    " Sparky,
    The journal is within specs, with no scoring or marks out of the ordinary. The bearings look good with a little blueing of the rollers but I have been told that this is normal. I also thought that the centre bearing race should be replaced due to the finish, but the new bearing race looks the same. The upper assembly cost me $455 aust so if I don't have to replace, then I would prefer not to.
    regs
    W "
  4. #4
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    14,276
    Default "Wayne.... The bearing can be
    "Wayne.... The bearing can be purchased at most companies that specialize in bearings only. It can also be purchased at "Precision Mfg & Sales" in Clearwater, Fl (1-800-237-5947), their part #495.
    Just make sure that it is installed properly ie depth, oil passage, etc.
    Joe[img][/img]"
    We occasionally have questions. If you fail to answer, it may affect ours.
  5. #5
    Default " Joe, Thanks again. Do y
    " Joe,
    Thanks again. Do you know any particular brand as I am in Australia?.The original is a Torrington AJ-47495-1 but I can't find it on the net and the local bearing supplier didn't have it listed. I am tending towards cleaning and reusing (with new seal) as it looks pretty good.
    regs
    W "
  6. #6
    Join Date
    Feb 2001
    Location
    Posts
    14,276
    Default "Wayne.... All I can do is ste
    "Wayne.... All I can do is steer you to Precision Mfg my friend. Hope this helps.
    http://www.precisionmfgsales.com/
    Joe (30+ Years With OMC)"
  7. #7
    Default " If the bearings are good why
    " If the bearings are good why replace them.After all a bearing is only there to provide a shape for the oil to form a wedge to keep parts seperated. Look at the cutlass bearing on an inboard prop shaft, water lubricated and made out of rubber.Just use fine 400 paper on the shaft ( and centre bearing shell)and polish to get a cross hatch pattern, the oil will work its magic. "
  8. #8
    Default " Joe/Sparky, Than
    " Joe/Sparky,
    Thanks for your help, I guess I am a little cautious as I am new to powerhead rebuilds. The reality is that the bearings are serviceable, I just worry too much.
    Thanks again.
    Wayne "
Similar Threads
  1. Gimbal bearing question
    By pjsomers2 in forum Volvo Penta Gas Engine Forum
    Last Post: 09-14-2010, 08:34 PM
  2. Bearing Question
    By valor21 in forum Johnson Evinrude Outboard Archive
    Last Post: 07-16-2009, 05:05 PM
  3. Gimbal bearing question
    By jrod1540 in forum OMC Sterndrive and Inboard Archive
    Last Post: 08-12-2008, 03:29 PM
  4. Engine bearing or tip of the shaft bearing question
    By Javier Cubero in forum Volvo Penta Gas Archive
    Last Post: 10-08-2006, 11:36 AM
  5. 2000 225 Evinrude Ficht Lower UnitCrank Bearing Question
    By wayne in forum Johnson Evinrude Outboard Archive
    Last Post: 07-17-2003, 03:39 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
