" Hi there,
I am trying to change the water impeller on the above, have removed the four bolts and the nut from the guide pin on the lower unit and it moved about 3/4" but when I try to split the lower unit away, the gear lever movers to reverse and it will not budge! Have removed all that I can see, but the lower unit is still held on by the gear linkage. How and where do I disconnect the linkage.
many thanks
Bob Layton
U.K.
Any ideas please "
