Pull start on 92 Envinrude 8hp Wonbt Pull
P
Pete camelo
Guest
The pull start seems to be &#
The pull start seems to be "locked" and won't pull...feels like it is in gear (but its not). It will "rewind" the little slack thats out..The mechanism that rotates up (like a gear) I think works..I mean it rotates when I manually turn it...the post that the cord wraps around is just stuck on the "pull" direction...sorry I don't know the parts names...any help would help..
It sounds like you need to lu
It sounds like you need to lube it spray some wd40 on it and try to work it loose and when you get it loose keep working it.
" Hi Pete,
Your motor has a
" Hi Pete,
Your motor has a lockout on the starter that prevents it from being pulled when the throttle is adanced too far. Try moving the throttle down to a slower position....
- Scott "
