Weak spark
ibnfshn
Advanced Contributor
" With the coils, wires and pl
" With the coils, wires and plugs eliminated, what else could causse weak spark? Thanks "
hi there ibnfhn
i might be
hi there ibnfhn
i might be able to help you there have you checked the spark plug if its dirty you should see a large carbon buld up causing it to do a little spark across the electrode and the meatle bit get a thin blade not much thicker then a hacksaw blade scrape around the electrode being extremmly carful not to damage the electrode then you go about setting gaps should not be much thicker then a screwdriver end small ) then just run a very fine bit of sand paper over the steal bit till its shiny then and i would also check your points it could be dirty just put a bit of thin cardbord between the points this will set it just right this is only a last resort) buy new spark plugs) only if the above fails
i can reckomend champion spark plugs
JASON 20+ YEARS WITH P&O AND WITH SPRIT OF TAS LINES
