K
Kory Glen
Guest
" I have a mid 60's (I
" I have a mid 60's (I think - don't know model number off hand) Johnson Seahorse 9.9 hp. It is bogging down when given gas and is running at far below the speeds that it used to. Engine will idle rough and then die after running awhile. Compression seems fine and both spark plugs are hot after running. I have torn the carb apart and cleaned it well (main jet looked fine and there was some gunk build-up in float. I have also taken the fuel pump apart and it seems clean. I also notice a lot of gas leaking out of engine after running. My first thought was a fuel filter, except that I can't find one, except for the filter paper in the fuel pump. Any ideas on what is wrong? I am at my witts end and don't think the engine is worth paying to have fixed. Any help would be GREATLY appreciated. "
