"this is a project motor that
"this is a project motor that I am fixing up to put on another boat......hard starting when cold,,,,,when cranking over several times there is a gas leak on an 1/8 hose,, which comes off a fitting on top of the engine under the flywheel cover,, on the port side just a little to the rear of the flywheel goes down past the fuel pump was unable to trace all the due to darkness... i can see that the rubber hose rotten and open at the top fitting
what is this hose for and why does it leak when cranking over..
why is this motor hard to start,, after 1st start,, starts very as long as warm
rebuilt carbs adjt floats to specs,,
rebuilt fuel pump
all new hose
new impeller"
rebuilt fuel pump
all new hose
new impeller"
