Themostat on 8V71
67roamer
Is the thermostat located in t
Is the thermostat located in the housing where the temperature guage sensor is?
If not where is it located
"there are two housings,it is
"there are two housings,it is located on the front of the head where the square shaped housing is bolted down by 4-3/8" bolts also, connected by the crossover pipe going to the other square thermostat housing on the front of other head on a 8v-71."
"Thanks for the info, I found
"Thanks for the info, I found the one side but did not know there is one on each side
Thanks again"
