1978 40 HP Mercury 402 Lower Unit Removal HELP
joe
Need help. I want to change
Need help. I want to change the water pump. I unbolted all lower unit bolts. Gently tapped the lower unit and it dropped about 3/4" and then stopped. Where do I disconnect the shift linkage from the powerhead to allow the unit to be removed. Or does it slip out like the drive shaft.
" Joe,
I'm not sure but,
" Joe,
I'm not sure but, look under the carbs to see if there's a screw or bolt that holds the shift linkage. Haven't seen the "Mercury Dude" on this board lately. Maybe he will help you on this pblm. "
" Sorry, been out of town.
Th
The shaft is splined. Make sure all bolts have been removed. There is one under the trim tab on the housing. It is possible that the shaft has a little corrosion. Be careful and check. If all bolts have been removed, try pushing the lower unit back up and then pull down. This will get a little more movement.
Good Luck and have Fun on the Water "
